The post-transcriptional regulatory system CSR controls the balance of metabolic pools in upper glycolysis of Escherichia coli
Manon Morin 1, 2 Delphine Ropers 1, * Fabien Letisse 2 Sandrine Laguerre 2 Jean-Charles Portais 2 Muriel Cocaign-Bousquet 2, * Brice Enjalbert 2
* Auteur correspondant
1 IBIS - Modeling, simulation, measurement, and control of bacterial regulatory networks
LAPM - Laboratoire Adaptation et pathogénie des micro-organismes [Grenoble], Inria Grenoble - Rhône-Alpes, Institut Jean Roget
Abstract : Metabolic control in Escherichia coli is a complex process involving multilevel regulatory systems but the involvement of post-transcriptional regulation is uncertain. The post-transcriptional factor CsrA is stated as being the only regulator essential for the use of glycolytic substrates. A dozen enzymes in the central carbon metabolism (CCM) have been reported as potentially controlled by CsrA, but its impact on the CCM functioning has not been demonstrated. Here, a multiscale analysis was performed in a wild-type strain and its isogenic mutant attenuated for CsrA (including growth parameters, gene expression levels, metabolite pools, abundance of enzymes and fluxes). Data integration and regulation analysis showed a coordinated control of the expression of glycolytic enzymes. This also revealed the imbalance of metabolite pools in the csrA mutant upper glycolysis, before the phosphofructokinase PfkA step. This imbalance is associated with a glucose-phosphate stress. Restoring PfkA activity in the csrA mutant strain suppressed this stress and increased the mutant growth rate on glucose. Thus, the carbon storage regulator system is essential for the effective functioning of the upper glycolysis mainly through its control of PfkA. This work demonstrates the pivotal role of post-transcriptional regulation to shape the carbon metabolism.
Liste complète des métadonnées
https://hal.inria.fr/hal-01418224
Contributeur : Delphine Ropers <>
Soumis le : vendredi 16 décembre 2016 - 14:42:33
Dernière modification le : jeudi 29 novembre 2018 - 11:22:04
Lien texte intégral
Collections
Citation
Manon Morin, Delphine Ropers, Fabien Letisse, Sandrine Laguerre, Jean-Charles Portais, et al.. The post-transcriptional regulatory system CSR controls the balance of metabolic pools in upper glycolysis of Escherichia coli. Molecular Microbiology, Wiley, 2016, 100 (4), pp.686-700. 〈http://onlinelibrary.wiley.com/doi/10.1111/mmi.13343/abstract?systemMessage=Wiley+Online+Library+will+be+unavailable+on+Saturday+17th+December+2016+at+09%3A00+GMT%2F+04%3A00+EST%2F+17%3A00+SGT+for+4hrs+due+to+essential+maintenance.Apologies+for+the+inconvenience〉. 〈10.1111/mmi.13343〉. 〈hal-01418224〉
Métriques
Consultations de la notice
223
