Abstract : Tree-based exploratory methods, like Branch-and-Bound (B&B) algorithms, are highly irregular applications which makes their design and implementation on graphics processing unit (GPU) challenging. In this paper, we present a multi-GPU B&B algorithm for solving large permutation-based combinatorial optimization problems. To tackle the problem of the irregular workload, we propose a hierarchical work stealing (WS) strategy that balances the workload inside the GPU and between different GPUs and CPU cores. Our B&B is based on an Integer-Vector-Matrix data structure instead of a pool of permutations, and work units exchanged are intervals of factoradics instead of sets of nodes. Two variants of the algorithm, using the same hierarchical WS strategy, are proposed: one for combinatorial optimization problems where the evaluation of nodes is costly and one for fine-grained problems. The latter variant uses a new hypercube-based WS strategy and a trigger mechanism to balance the work load inside the GPU. The proposed approach has been extensively experimented using the flowshop scheduling, the n-queens and the asymmetric travelling salesman problems as test-cases. The reported results show that the proposed hierarchical WS mechanism is capable of handling fine and coarse-grained types of workloads efficiently, reaching near-linear speed-up on up to four GPUs for a set of ten flowshop instances and large instances of fine-grained problems
