Functional Neuroimaging Group Studies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
Multi-subject statistical analysis is an essential step of neuroimaging studies, as it makes it possible to draw conclusions that hold with a prescribed confidence level for the population under study. The use of the linear assumption to model activation signals in brain images and their modulation by various factors has opened the possibility to rely on relatively simple estimation and statistical testing procedures. Specifically, the analysis of functional neuroimaging signals is typically carried out on a per-voxel basis, in the so-called mass univariate framework. However, the lack of power in neuroimaging studies has incited neuroscientists to develop new procedures to improve this framework: various solutions have been set up to take into account the spatial context in statistical inference or to deal with violations of distributional assumptions of the data. In this chapter, we review the general framework for group inference, the ensuing mixed-effects model design and its simplifications, together with the various solutions that have been considered to improve the standard mass-univariate testing framework.
paper.pdf (2.31 Mo) Télécharger le fichier
hal-01419347 , version 1 (19-12-2016)
  • HAL Id : hal-01419347 , version 1
Bertrand Thirion. Functional Neuroimaging Group Studies. Hernando Ombao; Martin Lindquist; Wesley Thompson; John Aston. Handbook of Neuroimaging Data Analysis, Chapman & Hall / CRC, 2016, Handbook of Modern Statistical methods, 9781482220971. ⟨hal-01419347⟩
196 Consultations
268 Téléchargements
