Research on Building Technology of Aquaculture Water Quality Real-Time Monitoring Software Platform
At present, the information level of the aquaculture water quality monitoring is relatively backward in China. Building a digital, networked, intelligent real-time dynamic aquaculture water quality monitoring system by the modern electronic information technology, communications technology and wireless sensor network technology will have an important significance for the factory aquaculture technological innovation. The system is not only able to detect the main indicators of the aquaculture water quality (temperature, PH, dissolved oxygen, turbidity, ammonia, etc.) in real-time, but also be able to do the data fusion and data mining through its software platform, and establish the water quality indicators historical database. This software platform can achieve display and analysis of the local or remote monitoring data in real-time and dynamically, which can provide an important technical means and scientific basis to improve the water utilization effectively, and reduce the pollutant emission in aquaculture. This article will focus on the building technology of the system software platform.
Informatique [cs]
