Study on the Detection and Warning System of Rice Disease Based on the GIS and IOT in Jilin Province
Rice disease which has intimate connection with climate has a tremendous impact on the output and quality of rice. The present paper intends to construct a web to monitor the climate environment of rice growing by making use of IOT(Internet of things) and to exactly spot the regions where related statistics are collected and warned by taking advantage of GIS and then by means of C# language and SQL server, to realize the visuality of system and database management. Thereafter, under fuzzy clustering algorithm based on the collected environmental data to judge whether the rice disease will happen and need warning in case that unnecessary lose is caused.The finding reveals that by practicing the present system in Rice Disease Department of Academy of Agricultural Science of Chang Chun, the system functions well in detecting the serious disease.
Informatique [cs]
