Conference papers
Sparse Supernodal Solver Using Hierarchical Compression over Runtime System
Abstract : In this talk, we present the PaStiX sparse supernodal solver, using hierarchical compression to reduce the burden on large blocks appearing during the nested dissection process. We compare the numerical stability, and the performance in terms of memory consumption and time to solution of different approaches by selecting when the compression of the factorized matrix occurs. In order to improve the efficiency of the sparse update kernel for both BLR (block low rank) and HODLR (hierarchically off-diagonal low-rank), we investigate the BDLR (boundary distance low-rank) method to preselect rows and columns in the low-rank approximation algorithm.
Complete list of metadata
https://hal.inria.fr/hal-01421379
Contributor : Pierre Ramet Connect in order to contact the contributor
Submitted on : Thursday, December 22, 2016 - 10:35:09 AM
Last modification on : Saturday, June 25, 2022 - 10:36:57 AM
Identifiers
  • HAL Id : hal-01421379, version 1
Collections
Citation
Grégoire Pichon, Eric Darve, Mathieu Faverge, Pierre Ramet, Jean Roman. Sparse Supernodal Solver Using Hierarchical Compression over Runtime System. SIAM Conference on Computation Science and Engineering (CSE'17), Feb 2017, Atlanta, United States. ⟨hal-01421379⟩
Share
Metrics
Record views
179
