Bounds for Learning from Evolutionary-Related Data in the Realizable Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ondřej Kuželka
  • Fonction : Auteur
  • PersonId : 982633
Yuyi Wang
  • Fonction : Auteur
  • PersonId : 996959
Jan Ramon
This paper deals with the generalization ability of classifiers trained from non-iid evolutionary-related data in which all training and testing examples correspond to leaves of a phylogenetic tree. For the re-alizable case, we prove PAC-type upper and lower bounds based on symmetries and matchings in such trees.
2016-ijcai-Kuzelka.pdf (207.81 Ko) Télécharger le fichier
hal-01422033 , version 1 (23-12-2016)
  • HAL Id : hal-01422033 , version 1
Ondřej Kuželka, Yuyi Wang, Jan Ramon. Bounds for Learning from Evolutionary-Related Data in the Realizable Case. International Joint Conference on Artificial Intelligence (IJCAI), Jul 2016, New York, United States. ⟨hal-01422033⟩
501 Consultations
68 Téléchargements
