New interface
Journal articles
A synoptic approach to the seismic sensing of heterogeneous fractures: from geometric reconstruction to interfacial characterization
Fatemeh Pourahmadian 1 Bojan B Guzina 1 Houssem Haddar 2
2 DeFI - Shape reconstruction and identification
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : A non-iterative waveform sensing approach is proposed toward (i) geometric reconstruction of penetrable fractures, and (ii) quantitative identification of their heterogeneous contact condition by seismic i.e. elastic waves. To this end, the fracture support Γ (which may be non-planar and unconnected) is first recovered without prior knowledge of the interfacial condition by way of the recently established approaches to non-iterative waveform tomography of heterogeneous fractures, e.g. the methods of generalized linear sampling and topological sensitivity. Given suitable approximation ˘ Γ of the fracture geometry, the jump in the displacement field across ˘ Γ i.e. the fracture opening displacement (FOD) profile is computed from remote sensory data via a regularized inversion of the boundary integral representation mapping the FOD to remote observations of the scattered field. Thus obtained FOD is then used as input for solving the traction boundary integral equation on ˘ Γ for the unknown (linearized) contact parameters. In this study, linear and possibly dissipative interactions between the two faces of a fracture are parameterized in terms of a symmetric, complex-valued matrix K(ξ) collecting the normal, shear, and mixed-mode coefficients of specific stiffness. To facilitate the high-fidelity inversion for K(ξ), a 3-step regularization algorithm is devised to minimize the errors stemming from the inexact geometric reconstruction and FOD recovery. The performance of the inverse solution is illustrated by a set of numerical experiments where a cylindrical fracture, endowed with two example patterns of specific stiffness coefficients, is illuminated by plane waves and reconstructed in terms of its geometry and heterogeneous (dissipative) contact condition.
Document type :
Journal articles
Complete list of metadata
Cited literature [56 references]  Display  Hide  Download
https://hal.inria.fr/hal-01422085
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Friday, December 23, 2016 - 4:55:52 PM
Last modification on : Friday, November 18, 2022 - 9:28:30 AM
Long-term archiving on: : Tuesday, March 21, 2017 - 5:47:01 AM
File
frac2b.pdf
Identifiers
Citation
Fatemeh Pourahmadian, Bojan B Guzina, Houssem Haddar. A synoptic approach to the seismic sensing of heterogeneous fractures: from geometric reconstruction to interfacial characterization. Computer Methods in Applied Mechanics and Engineering, 2017, 324, pp.395-412. ⟨10.1016/j.cma.2017.06.002⟩. ⟨hal-01422085⟩
Share
Metrics
Record views
294
Files downloads
117
