Simultaneous State Initialization and Gyroscope Bias Calibration in Visual Inertial aided Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2016
State of the art approaches for visual-inertial sensor fusion use filter-based or optimization-based algorithms. Due to the nonlinearity of the system, a poor initialization can have a dramatic impact on the performance of these estimation methods. Recently, a closed-form solution providing such an initialization was derived in [1]. That solution determines the velocity (angular and linear) of a monocular camera in metric units by only using inertial measurements and image features acquired in a short time interval. In this letter, we study the impact of noisy sensors on the performance of this closed-form solution. We show that the gyroscope bias, not accounted for in [1], significantly affects the performance of the method. Therefore, we introduce a new method to automatically estimate this bias. Compared to the original method, the new approach now models the gyroscope bias and is robust to it. The performance of the proposed approach is successfully demonstrated on real data from a quadrotor MAV.
hal-01423550 , version 1 (30-12-2016)
Jacques Kaiser, Agostino Martinelli, Flavio Fontana, Davide Scaramuzza. Simultaneous State Initialization and Gyroscope Bias Calibration in Visual Inertial aided Navigation. IEEE Robotics and Automation Letters, 2016, 2 (1), pp.18-25. ⟨10.1109/LRA.2016.2521413⟩. ⟨hal-01423550⟩
204 Consultations
0 Téléchargements
