An application-level solution for the dynamic reconfiguration of MPI applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current parallel environments aggregate large numbers of computational resources with a high rate of change in their availability and load conditions. In order to obtain the best performance in this type of infrastructures, parallel applications must be able to adapt to these changing conditions. This paper presents an application-level proposal to automatically and transparently adapt MPI applications to the available resources. Experimental results show a good degree of adaptability and a good performance in di↵erent availability scenarios.
vecpar.pdf (375.67 Ko) Télécharger le fichier
hal-01424263 , version 1 (02-01-2017)
  • HAL Id : hal-01424263 , version 1
Iván Cores, Patricia González, Emmanuel Jeannot, María J Martín, Gabriel Rodríguez. An application-level solution for the dynamic reconfiguration of MPI applications. 12th International Meeting on High Performance Computing for Computational Science, Jun 2016, Porto, Portugal. ⟨hal-01424263⟩
Collections
CNRS INRIA INRIA2
163 Consultations
92 Téléchargements
