Journal articles
Preserving Partial Order Runs in Parametric Time Petri Nets
Abstract : Parameter synthesis for timed systems aims at deriving parameter valuations satisfying a given property. In this paper we target concurrent systems. We use partial-order semantics for parametric time Petri nets as a way to both 1) cope with the well-known state-space explosion due to concurrency, and 2) significantly enhance the result of an existing synthesis algorithm. Given a reference parameter valuation, our approach synthesizes other valuations preserving the partial-order executions of the reference parameter valuation. We show the applicability of our approach using a tool applied to asynchronous circuits.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01425696
Contributor : Thomas Chatain Connect in order to contact the contributor
Submitted on : Tuesday, January 3, 2017 - 5:40:34 PM
Last modification on : Friday, July 8, 2022 - 10:09:35 AM
Long-term archiving on: : Tuesday, April 4, 2017 - 3:18:16 PM
File
IMPO-preprint.pdf
Identifiers
Citation
Étienne André, Thomas Chatain, César Rodriguez. Preserving Partial Order Runs in Parametric Time Petri Nets. ACM Transactions on Embedded Computing Systems (TECS), ACM, 2016, 16, pp.25. ⟨10.1145/3012283⟩. ⟨hal-01425696⟩
Share
Metrics
Record views
141
Files downloads
186
