Temperature is a key factor in Micromonas-virus interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The International Society of Microbiologial Ecology Journal Année : 2017
Sophie Rabouille
The genus Micromonas comprises phytoplankton that show among the widest latitudinal distributions on Earth, and members of this genus are recurrently infected by prasinoviruses in contrasted thermal ecosystems. In this study, we assessed how temperature influences the interplay between the main genetic clades of this prominent microalga and their viruses. The growth of three Micromonas strains (Mic-A, Mic-B, Mic-C) and the stability of their respective lytic viruses (MicV-A, MicV-B, MicV-C) were measured over a thermal range of 4–32.5 °C. Similar growth temperature optima (Topt) were predicted for all three hosts but Mic-B exhibited a broader thermal tolerance than Mic-A and Mic-C, suggesting distinct thermoacclimation strategies. Similarly, the MicV-C virus displayed a remarkable thermal stability compared with MicV-A and MicV-B. Despite these divergences, infection dynamics showed that temperatures below Topt lengthened lytic cycle kinetics and reduced viral yield and, notably, that infection at temperatures above Topt did not usually result in cell lysis. Two mechanisms operated depending on the temperature and the biological system. Hosts either prevented the production of viral progeny or maintained their ability to produce virions with no apparent cell lysis, pointing to a possible switch in the viral life strategy. Hence, temperature changes critically affect the outcome of Micromonas infection and have implications for ocean biogeochemistry and evolution.
Demory_Viruses_micromonas_temperature_2017_REVISED.pdf (1.6 Mo) Télécharger le fichier
Demory_Viruses_micromonas_temperature_2017_REVISED_SUPPLEMENTARY.pdf (193.67 Ko) Télécharger le fichier
hal-01464528 , version 1 (10-02-2017)
David Demory, Laure Arsenieff, Nathalie Simon, Christophe Six, Fabienne Rigaut-Jalabert, et al.. Temperature is a key factor in Micromonas-virus interactions. The International Society of Microbiologial Ecology Journal, 2017, 11 (3), pp.601-612. ⟨10.1038/ismej.2016.160⟩. ⟨hal-01464528⟩
1019 Consultations
299 Téléchargements
