DIET: A Scalable Toolbox to Build Network Enabled Servers on the Grid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of High Performance Computing Applications Année : 2006
Among existing grid middleware approaches, one simple, powerful, and flexible approach consists of using servers available in different administrative domains through the classical client-server or Remote Procedure Call (RPC) paradigm. Network Enabled Servers implement this model also called GridRPC. Clients submit computation requests to a scheduler whose goal is to find a server available on the grid. The aim of this paper is to give an overview of a middleware developed by the GRAAL team called DIET (for Distributed Interactive Engineering Tool-box). DIET is a hierarchical set of components used for the development of applications based on computational servers on the grid.
Fichier non déposé
hal-01429867 , version 1 (09-01-2017)
  • HAL Id : hal-01429867 , version 1
Eddy Caron, Frédéric Desprez. DIET: A Scalable Toolbox to Build Network Enabled Servers on the Grid. International Journal of High Performance Computing Applications, 2006, 20 (3), pp.23. ⟨hal-01429867⟩
129 Consultations
0 Téléchargements
