Audio Source Separation Based on Convolutive Transfer Function and Frequency-Domain Lasso Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses the problem of under-determined convolutive audio source separation in a semi-oracle configuration where the mixing filters are assumed to be known. We propose a separation procedure based on the convolutive transfer function (CTF), which is a more appropriate model for strongly reverberant signals than the widely-used multi-plicative transfer function approximation. In the short-time Fourier transform domain, source signals are estimated by minimizing the mixture fitting cost using Lasso optimization, with a $l_1$-norm regularization to exploit the spectral sparsity of source signals. Experiments show that the proposed method achieves satisfactory performance on highly reverberant speech mixtures, with a much lower computational cost compared to time-domain dual techniques.
ctf_ss.pdf (251.25 Ko) Télécharger le fichier
hal-01430754 , version 1 (10-01-2017)
Xiaofei Li, Laurent Girin, Radu Horaud. Audio Source Separation Based on Convolutive Transfer Function and Frequency-Domain Lasso Optimization. ICASSP 2017 - IEEE International Conference on Acoustics, Speech and Signal Processing, Mar 2017, New Orleans, United States. pp.541-545, ⟨10.1109/ICASSP.2017.7952214⟩. ⟨hal-01430754⟩
674 Consultations
742 Téléchargements
