Conference papers
Situational Awareness Using Distributed Data Fusion with Evidence Discounting
Abstract : Data fusion provides a means for combining pieces of information from various sources and sensors. This chapter presents a data fusion methodology for interdependent critical infrastructures that leverages a distributed algorithm that allows the sharing of the possible causes of faults or threats affecting the infrastructures, thereby enhancing situational awareness. Depending on the degree of coupling, the algorithm modulates the information content provided by each infrastructure using a data fusion technique called evidence discounting. The methodology is applied to a case study involving a group of dependent critical infrastructures. Simulation results demonstrate that the methodology is resilient to temporary faults in the critical infrastructure communications layer.
Document type :
Conference papers
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01431007
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, January 10, 2017 - 2:56:08 PM
Last modification on : Wednesday, October 14, 2020 - 4:11:55 AM
Long-term archiving on: : Tuesday, April 11, 2017 - 3:16:41 PM
File
978-3-319-26567-4_17_Chapter.p...
Identifiers
Citation
Antonio Di Pietro, Stefano Panzieri, Andrea Gasparri. Situational Awareness Using Distributed Data Fusion with Evidence Discounting. 9th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2015, Arlington, VA, United States. pp.281-296, ⟨10.1007/978-3-319-26567-4_17⟩. ⟨hal-01431007⟩
Share
Metrics
Record views
64
Files downloads
121
