A Software Architecture for Transportation Planning and Monitoring in a Collaborative Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Transportation planners require software support to easily monitor and dispatch transportation resources, especially when transportation is multi-modal and when resources from different companies in their network are being used. We call such an application a transportation control tower. This paper presents a software architecture for transportation control towers. It focuses in particular on the novel aspects of the software architecture. These are: the ability to easily configure the monitoring of resources and tasks; the ability to create the statements for monitoring resources and tasks based on the transportation plan; and the ability to dynamically adjust the monitoring statements. A prototype of the software architecture is implemented and evaluated on three usage scenarios.
370605_1_En_25_Chapter.pdf (309.94 Ko) Télécharger le fichier
hal-01437896 , version 1 (17-01-2017)
Paternité
Anne Baumgrass, Remco Dijkman, Paul Grefen, Shaya Pourmirza, Hagen Völzer, et al.. A Software Architecture for Transportation Planning and Monitoring in a Collaborative Network. 16th Working Conference on Virtual Enterprises (PROVE), Oct 2015, Albi, France. pp.277-284, ⟨10.1007/978-3-319-24141-8_25⟩. ⟨hal-01437896⟩
116 Consultations
160 Téléchargements
