On communication models when verifying equivalence properties (extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Symbolic models for security protocol verification, following the sem-inal ideas of Dolev and Yao, come in many flavors, even though they share the same ideas. A common assumption is that the attacker has complete control over the network: he can therefore intercept any message. Depending on the precise model this may be reflected either by the fact that any protocol output is directly routed to the adversary, or communications may be among any two participants, including the attacker — the scheduling between which exact parties the communication happens is left to the attacker. These two models may seem equivalent at first glance and, depending on the verification tools, either one or the other semantics is implemented. We show that, unsurprisingly, they indeed coincide for reachability properties. However, when we consider indistinguishability properties, we prove that these two semantics are incomparable. We also introduce a new semantics, where internal communications are allowed but messages are always eavesdropped by the attacker. We show that this new semantics yields strictly stronger equivalence relations. We also identify two subclasses of protocols for which the three semantics coincide. Finally, we implemented verification of trace equivalence for each of these semantics in the APTE tool and compare their performances on several classical examples.
main.pdf (456.12 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01438639 , version 1 (17-01-2017)
  • HAL Id : hal-01438639 , version 1
Kushal Babel, Vincent Cheval, Steve Kremer. On communication models when verifying equivalence properties (extended version). 6th International Conference on Principles of Security and Trust (POST), 2017, Uppsala, Sweden. ⟨hal-01438639⟩
Relations
476 Consultations
195 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
