A Risk-Based Approach Supporting Enterprise Architecture Evolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sérgio Guerreiro
  • Fonction : Auteur
  • PersonId : 998949
Enterprise architecture (EA) is a discipline driving change within organizations. The management of EA change is a challenging task for enterprise architects, due to the complex dependencies amongst EA models when evolving towards different alternatives (To-be models). In this paper, we present an approach supporting design decision during EA evolution. The idea is to reason on (To-be) models when evolving to a posterior state. To that end, we rationalize on a set of design decisions that are mapped on a non deterministic finite automaton, which is then evaluated by Markov decision processes. The idea consists of computing EA models valuations while integrating both alternatives rewards and risks metrics. In doing so, we consider risk as a correctness factor to choose the best alternative. Finally, we simulate our risk-based approach using a manufacturing scenario and discuss its usefulness and applicability.
978-3-319-25897-3_4_Chapter.pdf (0 B) Télécharger le fichier
hal-01442297 , version 1 (20-01-2017)
Paternité
Khaled Gaaloul, Sérgio Guerreiro. A Risk-Based Approach Supporting Enterprise Architecture Evolution. 8th Practice of Enterprise Modelling (P0EM), Nov 2015, Valencia, Spain. pp.43-56, ⟨10.1007/978-3-319-25897-3_4⟩. ⟨hal-01442297⟩
73 Consultations
34 Téléchargements
