Computations with p-adic numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
This document contains the notes of a lecture I gave at the "Journées Nationales du Calcul Formel" (JNCF) on January 2017. The aim of the lecture was to discuss low-level algorithmics for p-adic numbers. It is divided into two main parts: first, we present various implementations of p-adic numbers and compare them and second, we introduce a general framework for studying precision issues and apply it in several concrete situations.
Mots clés
cours.pdf (825.41 Ko) Télécharger le fichier
hal-01444183 , version 1 (23-01-2017)
Xavier Caruso. Computations with p-adic numbers. Journées Nationales de Calcul Formel, In press, Les cours du CIRM. ⟨hal-01444183⟩
459 Consultations
6298 Téléchargements
