Optimal Fleet Sizing of Personal Rapid Transit System
In this paper, we address the problem of determining the optimal fleet size for Personal Rapid Transit system (PRT). In our problem, we consider electric battery and distance constraints which are found in real world application of the PRT system. To tackle this problem, we propose two valid mathematical formulations that are able to find optimal fleet size. Extensive computational experiments show that the edge based formulation performs impressively well, in terms of solution quality and computational time in comparison to the node based formulation.
