HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
The Impact of the TPM Weights Distribution on Network Synchronization Time
Abstract : Two neural networks with randomly chosen initial weights may achieve the same weight vectors in the process of their mutual learning. This phenomenon is called a network synchronization, and can be used in cryptography to establish the keys for further communication. The time required to achieve consistent weights of networks depends on the initial similarity and on the size of the network. In the previous work related to this topic the weights in TPM networks are randomly chosen and no detailed research on used distribution is performed. This paper compares the synchronization time obtained for the network weights randomly chosen from either the uniform distribution or from the Gaussian distribution with different values of standard deviation. The synchronization time of the network is examined here as a function of different numbers of inputs and of various weights belonging to the intervals with varying sizes. The standard deviation of Gaussian distribution is selected depending on this interval size in order to compare networks with different weights intervals, which also constitutes a new approach for selecting the distribution’s parameters. The results of all analyzed networks are shown as a percentage of the synchronization time of a network with weights drawn from uniform distribution. The weights drawn from the Gaussian distribution with decreasing standard deviation have shorter synchronization time especially for a relatively small network.
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-01444486
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, January 24, 2017 - 10:41:14 AM
Last modification on : Wednesday, January 25, 2017 - 1:04:03 AM
Long-term archiving on: : Tuesday, April 25, 2017 - 6:07:27 PM
File
978-3-319-24369-6_37_Chapter.p...
Identifiers
Citation
Michał Dolecki, Ryszard Kozera. The Impact of the TPM Weights Distribution on Network Synchronization Time. 14th Computer Information Systems and Industrial Management (CISIM), Sep 2015, Warsaw, Poland. pp.451-460, ⟨10.1007/978-3-319-24369-6_37⟩. ⟨hal-01444486⟩
Share
Metrics
Record views
35
Files downloads
80
