A Pre-congruence Format for XY-simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Harsh Beohar
  • Fonction : Auteur
  • PersonId : 999418
Mohammad Reza Mousavi
  • Fonction : Auteur
  • PersonId : 999386
XY-simulation is a generalization of bisimulation that is parameterized with two subsets of actions. XY-simulation is known in the literature under different names such as modal refinement, partial bisimulation, and alternating simulation. In this paper, we propose a pre-congruence rule format for XY-simulation. The format allows for checking compositionality of XY-simulation for an arbitrary language with structural operational semantics, by performing very simple checks on the syntactic shape of the rules. We apply our format to derive concrete compositionality results for different notions of behavioral pre-order with respect to different process calculi in the literature.
978-3-319-24644-4_15_Chapter.pdf (521.87 Ko) Télécharger le fichier
hal-01446602 , version 1 (26-01-2017)
Paternité
Harsh Beohar, Mohammad Reza Mousavi. A Pre-congruence Format for XY-simulation. 6th Fundamentals of Software Engineering (FSEN), Apr 2015, Tehran, Iran. pp.215-229, ⟨10.1007/978-3-319-24644-4_15⟩. ⟨hal-01446602⟩
43 Consultations
104 Téléchargements
