Abstract : Our work was inspired by our modelling and verification of a cardiac pacemaker, which includes concurrent aspects and a set of interdependent and cyclic timing constraints. To model timing constraints in such systems, we present an approach based on the concept of timing interval. We provide a template-based timing constraint modelling scheme that could potentially be applicable to a wide range of modelling scenarios. We give a notation and Event-B semantics for the interval. The Event-B coding of the interval is decoupled from the application logic of the model, therefore a generative design of the approach is possible. We demonstrate our interval approach and its refinement through a small example. The example is verified, model-checked and animated (manually validated) with the ProB animator.
https://hal.inria.fr/hal-01446607 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, January 26, 2017 - 10:43:45 AM Last modification on : Saturday, June 8, 2019 - 2:20:03 PM Long-term archiving on: : Friday, April 28, 2017 - 5:52:05 AM
Gintautas Sulskus, Michael Poppleton, Abdolbaghi Rezazadeh. An Interval-Based Approach to Modelling Time in Event-B. 6th Fundamentals of Software Engineering (FSEN), Apr 2015, Tehran, Iran. pp.292-307, ⟨10.1007/978-3-319-24644-4_20⟩. ⟨hal-01446607⟩
