Rotor speed, load torque and parameters estimations of a permanent magnet synchronous motor using extended observer forms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Control Theory and Applications Année : 2017
This paper presents a new approach to estimate states and parameters of the permanent magnet synchronous motor (PMSM) in the presence of unknown load torque disturbance. Indeed, it highlights an auxiliary dynamics that is added to the PMSM model. Thereby, it supplies a change of coordinates that transforms the extended model (PMSM model together with the auxiliary dynamics) into the so-called extended nonlinear observer forms. It turns out that the obtained form provides two observer normal forms. One of them supports the well-know high gain observer which is used to estimate the speed and the unknown load torque. The second one which is affine in the parameters enables us to estimate simultaneously the states and motor parameters by means of an adaptive observer. Performance of the proposed method is illustrated by the simulations results.
vf.pdf (571.46 Ko) Télécharger le fichier
hal-01447955 , version 1 (08-03-2017)
Ramdane Tami, Driss Boutat, Gang Zheng, Frédéric Kratz, Rachid El El Gouri. Rotor speed, load torque and parameters estimations of a permanent magnet synchronous motor using extended observer forms. IET Control Theory and Applications, 2017, 11 (9), pp.1485-1492. ⟨10.1049/iet-cta.2016.0226⟩. ⟨hal-01447955⟩
378 Consultations
1886 Téléchargements
