New interface
Conference papers
On communication models when verifying equivalence properties
Kushal Babel 1 Vincent Cheval 2 Steve Kremer 2
2 PESTO - Proof techniques for security protocols
Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : Symbolic models for security protocol verification, following the sem-inal ideas of Dolev and Yao, come in many flavors, even though they share the same ideas. A common assumption is that the attacker has complete control over the network: he can therefore intercept any message. Depending on the precise model this may be reflected either by the fact that any protocol output is directly routed to the adversary, or communications may be among any two participants, including the attacker — the scheduling between which exact parties the communication happens is left to the attacker. These two models may seem equivalent at first glance and, depending on the verification tools, either one or the other semantics is implemented. We show that, unsurprisingly, they indeed coincide for reachability properties. However, when we consider indistinguishability properties, we prove that these two semantics are incomparable. We also introduce a new semantics, where internal communications are allowed but messages are always eavesdropped by the attacker. We show that this new semantics yields strictly stronger equivalence relations. We also identify two subclasses of protocols for which the three semantics coincide. Finally, we implemented verification of trace equivalence for each of these semantics in the APTE tool and compare their performances on several classical examples.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01450898
Contributor : Steve Kremer Connect in order to contact the contributor
Submitted on : Tuesday, January 31, 2017 - 2:35:32 PM
Last modification on : Friday, November 4, 2022 - 3:02:47 PM
Long-term archiving on: : Monday, May 1, 2017 - 2:11:53 PM
File
main.pdf
Identifiers
  • HAL Id : hal-01450898, version 1
Collections
Relations
Citation
Kushal Babel, Vincent Cheval, Steve Kremer. On communication models when verifying equivalence properties. 6th International Conference on Principles of Security and Trust (POST), Apr 2017, Uppsala, Sweden. ⟨hal-01450898⟩
Share
Metrics
Record views
249
Files downloads
202
