Abstract : Planning green factories implies increased complexity depending on specific planning requirements and contradictory planning targets; these aspects challenge present methods and tool for factory planning. To properly face these challenges with limited time and resources (typical of planning projects) , a factory planning approach that particularly addresses green has to be adaptable to specific cases and aligned with the green vision of the factory. This paper proposes a modular Green Factory Planning and describes its main components. The conceptual elements for a framework and a planning process are presented and differences in methods and tool applications are described in comparison to established approaches. The method and tools are combined to planning modules, linked with a clear information flow as well as responsibility definition. A use case for a typical module that specifically considers energy consumption shows the potential of green as integrated vision for factory planning.
Florian Mueller, Alessandro Cannata, Bojan Stahl, Marco Taisch, Sebastian Thiede, et al.. Green Factory Planning. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.167-174, ⟨10.1007/978-3-642-41266-0_21⟩. ⟨hal-01452110⟩
