Simple Priced Timed Games Are Not That Simple - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Priced timed games are two-player zero-sum games played on priced timed automata (whose locations and transitions are labeled by weights modeling the costs of spending time in a state and executing an action, respectively). The goals of the players are to minimise and maximise the cost to reach a target location, respectively. We consider priced timed games with one clock and arbitrary (positive and negative) weights and show that, for an important subclass of theirs (the so-called simple priced timed games), one can compute, in exponential time, the optimal values that the players can achieve, with their associated optimal strategies. As side results, we also show that one-clock priced timed games are determined and that we can use our result on simple priced timed games to solve the more general class of so-called reset-acyclic priced timed games (with arbitrary weights and one-clock).
main.pdf (630.28 Ko) Télécharger le fichier
hal-01452621 , version 1 (02-02-2017)
Copyright (Tous droits réservés)
Thomas Brihaye, Gilles Geeraerts, Axel Haddad, Engel Lefaucheux, Benjamin Monmege. Simple Priced Timed Games Are Not That Simple. Proceedings of the 35th IARCS Annual Conference on Foundations of Software Technology and Theoretical Computer Science (FSTTCS'15), Dec 2015, Bangalore, India. pp.278-292, ⟨10.4230/LIPIcs.FSTTCS.2015.p⟩. ⟨hal-01452621⟩
566 Consultations
66 Téléchargements
