Modeling Distributed Platforms from Application Traces for Realistic File Transfer Simulation - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1, 2) , (3, 2) , (4, 1) , (5) , (1) , (6, 2)
1
2
3
4
5
6
Simulation is a fast, controlled, and reproducible way to evaluate new algorithms for distributed computing platforms in a variety of conditions. However, the realism of simulations is rarely assessed, which critically questions the applicability of a whole range of ndings. In this paper, we present our eorts to build platform models from application traces, to allow for the accurate simulation of le transfers across a distributed infrastructure. File transfers are key to performance, as the variability of le transfer times has important consequences on the dataow of the application. We present a methodology to build realistic platform models from application traces and provide a quantitative evaluation of the accuracy of the derived simulations. Results show that the proposed models are able to correctly capture real-life variability and signicantly outperform the state-of-the-art model.
article-1_hal.pdf (453.02 Ko) Télécharger le fichier
Dates and versions
hal-01452694 , version 1 (02-02-2017)
Identifiers
  • HAL Id : hal-01452694 , version 1
Cite
Anchen Chai, Mohammad-Mahdi Bazm, Sorina Camarasu-Pop, Tristan Glatard, Hugues Benoit-Cattin, et al.. Modeling Distributed Platforms from Application Traces for Realistic File Transfer Simulation. 17th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing., May 2017, Madrid, Spain. ⟨hal-01452694⟩
766 View
390 Download
Share
