Development of a Catchment Management Tool to Assess Environmental Risk from Nutrient Loadings Using Open Source GIS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ian Packham
  • Fonction : Auteur
  • PersonId : 1000445
Eva Mockler
  • Fonction : Auteur
  • PersonId : 1000446
Michael Bruen
  • Fonction : Auteur
  • PersonId : 851509
A Catchment Management Tool (CMT) is being developed for the Irish Environmental Protection Agency (EPA) that will allow River Basin Managers to evaluate the environmental risk from organic and inorganic nutrient loadings due to various land uses and human activities. The CMT was built using Open Source GIS (Geographical Information System) software, to facilitate development and widen the research user-base of the tool. The user interface of the CMT is designed to be flexible to allow local knowledge to be included in the system as well as the possibility to try what-if scenarios in relation to environmental assessment. Contaminant loadings are calculated from publicly available data and hydrogeologically susceptible areas (HSAs) are formed by combining soil and geological GIS layers. Further combinations of Loadings and HSAs allow Critical Source Areas to be delineated that identify areas contributing significant amounts of a given contaminant to any selected water body.
978-3-642-41151-9_25_Chapter.pdf (518.04 Ko) Télécharger le fichier
hal-01457456 , version 1 (06-02-2017)
Paternité
Ian Packham, Eva Mockler, Michael Bruen. Development of a Catchment Management Tool to Assess Environmental Risk from Nutrient Loadings Using Open Source GIS. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.262-270, ⟨10.1007/978-3-642-41151-9_25⟩. ⟨hal-01457456⟩
68 Consultations
70 Téléchargements
