SVOD – System for Visualizing of Oncological Data and Their Semantic Enhancement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Miroslav Kubásek
  • Fonction : Auteur
  • PersonId : 983231
Jiří Hřebíček
  • Fonction : Auteur
  • PersonId : 983197
Ladislav Dušek
  • Fonction : Auteur
  • PersonId : 903751
Jan Mužík
  • Fonction : Auteur
  • PersonId : 1000491
Jiří Kalina
  • Fonction : Auteur
  • PersonId : 1000442
We present an overview of the SVOD web portal (System for Visualizing of Oncological Data) which is focused on population risk analyses related to cancer epidemiology and show its integration with the FP7 project TaToo (Tagging Tool based on a Semantic Discovery Framework). The developed TaToo Tools provide a semantic web solution in order to close the discovery gap that prevents full and easy access to specific web resources. Furhter more we will discuss in detail the used ontological resources, the integration of TaToo Tools into the SVOD portal together with the evaluation of this integration.
978-3-642-41151-9_56_Chapter.pdf (606.48 Ko) Télécharger le fichier
hal-01457490 , version 1 (06-02-2017)
Paternité
Miroslav Kubásek, Jiří Hřebíček, Ladislav Dušek, Jan Mužík, Jiří Kalina. SVOD – System for Visualizing of Oncological Data and Their Semantic Enhancement. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.597-607, ⟨10.1007/978-3-642-41151-9_56⟩. ⟨hal-01457490⟩
135 Consultations
66 Téléchargements
