NEVE: A Neuro-Evolutionary Ensemble for Adaptive Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work describes the use of a quantum-inspired evolutionary algorithm (QIEA-R) to construct a weighted ensemble of neural network classifiers for adaptive learning in concept drift problems. The proposed algorithm, named NEVE (meaning Neuro-EVolutionary Ensemble), uses the QIEA-R to train the neural networks and also to determine the best weights for each classifier belonging to the ensemble when a new block of data arrives. After running eight simulations using two different datasets and performing two different analysis of the results, we show that NEVE is able to learn the data set and to quickly respond to any drifts on the underlying data, indicating that our model can be a good alternative to address concept drift problems. We also compare the results reached by our model with an existing algorithm, Learn++.NSE, in two different nonstationary scenarios.
978-3-642-41142-7_64_Chapter.pdf (281.82 Ko) Télécharger le fichier
hal-01459656 , version 1 (07-02-2017)
Paternité
Tatiana Escovedo, André Da Cruz, Marley Vellasco, Adriano Soares Koshiyama. NEVE: A Neuro-Evolutionary Ensemble for Adaptive Learning. 9th Artificial Intelligence Applications and Innovations (AIAI), Sep 2013, Paphos, Greece. pp.636-645, ⟨10.1007/978-3-642-41142-7_64⟩. ⟨hal-01459656⟩
67 Consultations
68 Téléchargements
