Quantifying Windows File Slack Size and Stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Slack space can be used to hide data from the operating system and other users. While some forms of data hiding are easily detectable, others are subtle and require an experienced forensic practitioner to discover the hidden data. The amount of data that can be hidden varies with the type of slack space and environmental parameters such as filesystem block size and partition alignment. This paper evaluates the amount of file slack space available in Windows systems and the stability of slack space over time with respect to system updates. Measurements of the file slack for eighteen versions of Microsoft Windows with the NTFS filesystem reveal that many of the files change very little during system updates and are, thus, highly suitable for hiding data. A model is presented for estimating the amount of data that can be hidden in the file slack space of Windows filesystems of arbitrary size.
978-3-642-41148-9_13_Chapter.pdf (782.47 Ko) Télécharger le fichier
hal-01460605 , version 1 (07-02-2017)
Paternité
Martin Mulazzani, Sebastian Neuner, Peter Kieseberg, Markus Huber, Sebastian Schrittwieser, et al.. Quantifying Windows File Slack Size and Stability. 9th International Conference on Digital Forensics (DF), Jan 2013, Orlando, FL, United States. pp.183-193, ⟨10.1007/978-3-642-41148-9_13⟩. ⟨hal-01460605⟩
109 Consultations
875 Téléchargements
