Reducing the Time Required for Hashing Operations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Due to the increasingly massive amounts of data that need to be analyzed in digital forensic investigations, it is necessary to automatically recognize suspect files and filter out non-relevant files. To achieve this goal, digital forensic practitioners employ hashing algorithms to classify files into known-good, known-bad and unknown files. However, a typical personal computer may store hundreds of thousands of files and the task becomes extremely time-consuming. This paper attempts to address the problem using a framework that speeds up processing by using multiple threads. Unlike a typical multithreading approach, where the hashing algorithm is performed by multiple threads, the proposed framework incorporates a dedicated prefetcher thread that reads files from a device. Experimental results demonstrate a runtime efficiency of nearly 40% over single threading.
978-3-642-41148-9_7_Chapter.pdf (1.41 Mo) Télécharger le fichier
hal-01460624 , version 1 (07-02-2017)
Paternité
Frank Breitinger, Kaloyan Petrov. Reducing the Time Required for Hashing Operations. 9th International Conference on Digital Forensics (DF), Jan 2013, Orlando, FL, United States. pp.101-117, ⟨10.1007/978-3-642-41148-9_7⟩. ⟨hal-01460624⟩
124 Consultations
522 Téléchargements
