Secure Image Deduplication in Cloud Storage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hongyang Yan
  • Fonction : Auteur
  • PersonId : 1001292
Lingling Xu
  • Fonction : Auteur
  • PersonId : 1001293
With the great development of cloud computing in recent years, the explosive increasing of image data, the mass of information storage, and the application demands for high availability of data, network backup is facing an unprecedented challenge. Image deduplication technology is proposed to reduce the storage space and costs. To protect the confidentiality of the image, the notion of convergent encryption has been proposed. In the deduplication system, the image will be encrypted/ decrypted with a convergent encryption keywhich is derived by computing the hash value of the image content. It means that identical image copies will generate the same ciphertext, which used to check the duplicate image copy. Security analysis makes sure that this system is secure.
978-3-319-24315-3_25_Chapter.pdf (434.48 Ko) Télécharger le fichier
hal-01466226 , version 1 (13-02-2017)
Paternité
Han Gang, Hongyang Yan, Lingling Xu. Secure Image Deduplication in Cloud Storage. 3rd International Conference on Information and Communication Technology-EurAsia (ICT-EURASIA) and 9th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Oct 2015, Daejon, South Korea. pp.243-251, ⟨10.1007/978-3-319-24315-3_25⟩. ⟨hal-01466226⟩
124 Consultations
503 Téléchargements
