Low-Power Processors Require Effective Memory Partitioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The ever increasing complexity of embedded systems demands for rising memory size, and larger memories increase the power drain. In this work, we exploit banked memories with independent low-leakage retention mode in event-driven applications. The resulting energy saving for a given number of banks is close to the maximum achievable value, since the memory banks access pattern of event-driven applications presents a high temporal locality, leading to a low saving loss due to wake-up transitions. Results show an energy reduction up to 77.4% for a memory of ten banks with a partition overhead of 1%.
978-3-642-38853-8_7_Chapter.pdf (231.26 Ko) Télécharger le fichier
hal-01466703 , version 1 (13-02-2017)
Paternité
Leonardo Steinfeld, Marcus Ritt, Fernando Silveira, Luigi Carro. Low-Power Processors Require Effective Memory Partitioning. 4th International Embedded Systems Symposium (IESS), Jun 2013, Paderborn, Germany. pp.73-81, ⟨10.1007/978-3-642-38853-8_7⟩. ⟨hal-01466703⟩
80 Consultations
47 Téléchargements
