Narratives of an Outsourced Information Systems Failure in a Small Enterprise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this study we investigate a case of an outsourced information systems (IS) failure (OISF) within the collaborative partnership among asymmetric partners. A small and medium-sized enterprise (SME) is dealing with an independent software vendor (ISV) conducting a project of implementing an IS that fails. We used a narrative research methodology for our enquiry. In the construction of our narrative we followed the OISF framework as a theoretical touchstone. As a major conclusion we found that asymmetric collaborations with partners with inadequate managerial and technical IT capabilities are extremely prone to OISF’s. We showed that an outcome-based and fixed price contract is not an adequate instrument to conduct such a partnership and to avoid a failure.
978-3-642-38862-0_4_Chapter.pdf (354.52 Ko) Télécharger le fichier
hal-01467813 , version 1 (14-02-2017)
Paternité
Jan Devos, Hendrik Van Landeghem, Dirk Deschoolmeester. Narratives of an Outsourced Information Systems Failure in a Small Enterprise. InternationalWorking Conference on Transfer and Diffusion of IT (TDIT), Jun 2013, Bangalore, India. pp.57-72, ⟨10.1007/978-3-642-38862-0_4⟩. ⟨hal-01467813⟩
193 Consultations
110 Téléchargements
