An MDA Approach for PLM System Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Design and reconfiguration of industrial information systems is an important issue for SME/SMI. In this context, these small enterprises need tools and methods that allow them to adapt their system to their business while ensuring its consistency. The aim of this paper is to provide an approach for both the design method and the control method. This approach for PLM (Product lifecycle management) system is based on MDE (Model Driving Engineering). First, we will present a metamodel for PLM and the model transformation concepts. Then, we will present an application with the Audros PLM system.
Mots clés
978-3-642-40361-3_28_Chapter.pdf (344.32 Ko) Télécharger le fichier
hal-01470623 , version 1 (17-02-2017)
Paternité
Onur Yildiz, Lilia Gzara, Philippe Pernelle, Michel Tollenaere. An MDA Approach for PLM System Design. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.216-223, ⟨10.1007/978-3-642-40361-3_28⟩. ⟨hal-01470623⟩
321 Consultations
220 Téléchargements
