Abstract : We consider the following generalization of the binary search problem. A search strategy is required to locate an unknown target node $t$ in a given tree $T$. Upon querying a node $v$ of the tree, the strategy receives as a reply an indication of the connected component of $T\setminus\{v\}$ containing the target $t$. The cost of querying each node is given by a known non-negative weight function, and the considered objective is to minimize the total query cost for a worst-case choice of the target.
Designing an optimal strategy for a weighted tree search instance is known to be strongly NP-hard, in contrast to the unweighted variant of the problem which can be solved optimally in linear time. Here, we show that weighted tree search admits a quasi-polynomial time approximation scheme: for any $0 < \varepsilon < 1$, there exists a $(1+\varepsilon)$-approximation strategy with a computation time of $n^{O(\log n / \varepsilon^2)}$. Thus, the problem is not APX-hard, unless $NP \subseteq DTIME(n^{O(\log n)})$. By applying a generic reduction, we obtain as a corollary that the studied problem admits a polynomial-time $O(\sqrt{\log n})$-approximation. This improves previous $\hat O(\log n)$-approximation approaches, where the $\hat O$-notation disregards $O(\mathrm{poly}\log\log n)$-factors.
