Modular Framework for Reliable LCA-Based Indicators Supporting Supplier Selection within Complex Supply Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Carlo Brondi
  • Fonction : Auteur
  • PersonId : 1002142
Rosanna Fornasiero
  • Fonction : Auteur
Ludovico Vidali
  • Fonction : Auteur
With increased environmental awareness, a large amount of studies on green supplier selection has been promoted in the past decade. However the application of traditional impact assessments methodologies to fragmented and globalized supply chains is slowed down by provision of reliable data. Therefore, a comprehensive basis for Green Supplier Selection Model (GSSM) is proposed in this paper. In particular this paper proposes an index based on Life-Cycle-Assessment (LCA) to assess environmental burden of the whole company manufacturing activities. The resulting Company Environmental Performance Index (CEPI) can be used for sectoral benchmark to assess Company environmental Eco-Efficiency. The general methodology is presented with two strategic aims: the easy implementation of available data in standardized models and the reliable assessment of best performers within different manufacturing chains. Finally an application of such methodology to industrial cluster is discussed.
978-3-642-40352-1_26_Chapter.pdf (271.76 Ko) Télécharger le fichier
hal-01472242 , version 1 (20-02-2017)
Paternité
Carlo Brondi, Rosanna Fornasiero, Manfredi Vale, Ludovico Vidali, Federico Brugnoli. Modular Framework for Reliable LCA-Based Indicators Supporting Supplier Selection within Complex Supply Chains. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.200-207, ⟨10.1007/978-3-642-40352-1_26⟩. ⟨hal-01472242⟩
121 Consultations
110 Téléchargements
