Abstract : The paper discusses the advancement in the mass-customization of building components referring to Robot-Assisted Manufacturing. It is presented how the contemporary employment of Robotics offers a perspective of flexible alternative to traditional serial production system. Different Robot-Assisted fabrication methods are discussed through built experimental case studies at different scales. It is finally argued how Robotic production in architecture is significantly shifting the approach in design towards a model including material and fabrication constraints.
https://hal.inria.fr/hal-01472255 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, February 20, 2017 - 4:13:56 PM Last modification on : Thursday, March 5, 2020 - 4:44:57 PM Long-term archiving on: : Sunday, May 21, 2017 - 3:13:48 PM
Ingrid Paoletti, Roberto Naboni. Robotics in the Construction Industry: Mass Customization or Digital Crafting?. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.294-300, ⟨10.1007/978-3-642-40352-1_37⟩. ⟨hal-01472255⟩
