Multimodal Processes Rescheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Grzegorz Bocewicz
  • Fonction : Auteur
  • PersonId : 1002198
Zbigniew A. Banaszak
  • Fonction : Auteur
  • PersonId : 1002199
Peter Nielsen
  • Fonction : Auteur
  • PersonId : 991697
Quang-Vinh Dang
  • Fonction : Auteur
  • PersonId : 1002194
Cyclic scheduling problems concerning multimodal processes are usually observed in FMSs producing multi-type parts where the Automated Guided Vehicles System (AGVS) plays a role of a material handling system. Schedulability analysis of concurrently flowing cyclic processes (SCCP) executed in these kinds of systems can be considered using a declarative modeling framework. Proposed representation provides a unified way for performance evaluation of local cyclic as well as supported by them multimodal processes. The main question regards of reachability of a SCCP cyclic behavior. In this context, the sufficient conditions guarantee the reachability of both local and multimodal processes cyclic steady state spaces are discussed.
978-3-642-40352-1_67_Chapter.pdf (753.47 Ko) Télécharger le fichier
hal-01472288 , version 1 (20-02-2017)
Paternité
Grzegorz Bocewicz, Zbigniew A. Banaszak, Peter Nielsen, Quang-Vinh Dang. Multimodal Processes Rescheduling. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.534-541, ⟨10.1007/978-3-642-40352-1_67⟩. ⟨hal-01472288⟩
91 Consultations
78 Téléchargements
