Innovating a Business Model for Services with Storytelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Morten Lund
  • Fonction : Auteur
  • PersonId : 1002223
In recent years, the notion of business models has been able to innovate the way companies create new business opportunities. However, because business models most often rest on a complex interplay of several actors, there is a need to be able to explore the nature of a business model.This paper will propose to describe a business model by means of storytelling. Also, the paper will introduce the notion of archetypes of business models with the aim to seek a pattern in the light of the numerous business models available. Two cases will illustrate and discuss storytelling and archetypes, giving rise to conclude that they represent a valuable approach to understanding and innovating business models.
978-3-642-40352-1_85_Chapter.pdf (156.99 Ko) Télécharger le fichier
hal-01472307 , version 1 (20-02-2017)
Paternité
Morten Lund. Innovating a Business Model for Services with Storytelling. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.677-684, ⟨10.1007/978-3-642-40352-1_85⟩. ⟨hal-01472307⟩
128 Consultations
262 Téléchargements
