Architecture of Network Environment for High-Risk Security Experimentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Adequate Environment for conducting security experiments and test under controlled, safe, repeatable and as-realistic-as-possible conditions, are a key element for the research and development of adequate security solutions and the training of security personnel and researchers. In this paper, a new large-scale network experimental environment for high-risk security research was put forward. The main idea was using isolated computing clusters to obtain high levels of scale, manageability and safety by heavily leveraging virtualization technology, separating experiment and control network and multilayer sanitization.
978-3-642-36818-9_53_Chapter.pdf (336.11 Ko) Télécharger le fichier
hal-01480206 , version 1 (01-03-2017)
Paternité
Xiaohui Kuang, Xiang Li, Jinjing Zhao. Architecture of Network Environment for High-Risk Security Experimentation. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.479-484, ⟨10.1007/978-3-642-36818-9_53⟩. ⟨hal-01480206⟩
151 Consultations
112 Téléchargements
