Experimental evaluation of magnified haptic feedback for robot-assisted needle insertion and palpation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The International Journal of Medical Robotics and Computer Assisted Surgery Année : 2017
Background: Haptic feedback has been proven to play a key role in enhancing the performance of teleoperated medical procedures. However, due to safety issues, commercially-available medical robots do not currently provide the clinician with haptic feedback. Methods: This work presents the experimental evaluation of a teleoperation system for robot-assisted medical procedures able to provide magnified haptic feedback to the clinician. Forces registered at the operating table are magnified and provided to the clinician through a 7-DoF haptic interface. The same interface is also used to control the motion of a 6-DoF slave robotic manipulator. The safety of the system is guaranteed by a time-domain passivity-based control algorithm. Results: We carried out two experiments on stiffness discrimination (during palpation and needle insertion) and one experiment on needle guidance. Conclusions: Our haptic-enabled teleoperation system improved the performance with respect to direct hand interaction of 80%, 306%, and 27% in stiffness discrimination through palpation, stiffness discrimination during needle insertion, and guidance, respectively.
Meli-IJMRCAS-UR5.pdf (8.39 Mo) Télécharger le fichier
hal-01482249 , version 1 (03-03-2017)
Leonardo Meli, Claudio Pacchierotti, Domenico Prattichizzo. Experimental evaluation of magnified haptic feedback for robot-assisted needle insertion and palpation. The International Journal of Medical Robotics and Computer Assisted Surgery, 2017, 13 (4), pp.1-14. ⟨10.1002/rcs.1809⟩. ⟨hal-01482249⟩
453 Consultations
620 Téléchargements
