Microphone Array Signal Processing for Robot Audition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Robot audition for humanoid robots interacting naturally with humans in an unconstrained real-world environment is a hitherto unsolved challenge. The recorded microphone signals are usually distorted by background and interfering noise sources (speakers) as well as room reverberation. In addition, the movements of a robot and its actuators cause ego-noise which degrades the recorded signals significantly. The movement of the robot body and its head also complicates the detection and tracking of the desired, possibly moving , sound sources of interest. This paper presents an overview of the concepts in microphone array processing for robot audition and some recent achievements.
HSCMA_2017_final.pdf (1.5 Mo) Télécharger le fichier
hal-01485322 , version 1 (08-03-2017)
Heinrich Löllmann, Alastair Moore, Patrick Naylor, Boaz Rafaely, Radu Horaud, et al.. Microphone Array Signal Processing for Robot Audition. IEEE Workshop on Hands-free Speech Communication and Microphone Arrays, IEEE Signal Processing Society, Mar 2017, San Francisco, United States. pp.51-55, ⟨10.1109/HSCMA.2017.7895560⟩. ⟨hal-01485322⟩
450 Consultations
1354 Téléchargements
