Towards Distributed Reactive Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reactive applications is a wide class of software that responds to user input, network messages, and other events. Recent research on reactive languages successfully addresses the drawbacks of the Observer pattern – the traditional way reactive applications are implemented in the object-oriented setting – by introducing time-changing values and other ad-hoc programming abstractions.However, those approaches are limited to local settings, but most applications are distributed. We highlight the research challenges of distributed reactive programming and present a research roadmap. We argue that distributed reactive programming not only moves reactive languages to the distributed setting, but is a promising concept for middleware and distributed systems design.
978-3-642-38493-6_16_Chapter.pdf (170.55 Ko) Télécharger le fichier
hal-01486029 , version 1 (09-03-2017)
Paternité
Guido Salvaneschi, Joscha Drechsler, Mira Mezini. Towards Distributed Reactive Programming. 15th International Conference on Coordination Models and Languages (COORDINATION), Jun 2013, Florence, Italy. pp.226-235, ⟨10.1007/978-3-642-38493-6_16⟩. ⟨hal-01486029⟩
102 Consultations
272 Téléchargements
