Abstract : Active objects offer a paradigm which simplifies writing distributed applications. Since each active object has a single thread of control, data races are prevented. However, this programming model has its limitations: it is deadlock-prone, and it is not efficient on multicore machines. To overcome these limitations, we present an extension of the active object model, called multi-active objects, that allows each activity to be multi-threaded. The new model is implemented as a Java library; it relies on method annotations to decide which requests can be run in parallel. It provides implicit parallelism, sparing the programmer from low-level concurrency mechanisms. We define the operational semantics of the multi-active objects and study the basic properties of this model. Finally, we show with two applications that our approach is easy to program and efficient.
https://hal.inria.fr/hal-01486037 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, March 9, 2017 - 3:53:15 PM Last modification on : Thursday, August 4, 2022 - 4:54:25 PM Long-term archiving on: : Saturday, June 10, 2017 - 2:33:25 PM
Ludovic Henrio, Fabrice Huet, Zsolt István. Multi-threaded Active Objects. 15th International Conference on Coordination Models and Languages (COORDINATION), Jun 2013, Florence, Italy. pp.90-104, ⟨10.1007/978-3-642-38493-6_7⟩. ⟨hal-01486037⟩
