Strengthening Consistency in the Cassandra Distributed Key-Value Store - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distributed highly-available key-value stores have emerged as important building blocks for applications handling large amounts of data. The Apache Cassandra system is one such popular store combining a key distribution mechanism based on consistent hashing with eventually-consistent data replication and membership mechanisms. Cassandra fits well applications that share its semantics but is a poor choice for traditional applications that require strong data consistency. In this work we strengthen the consistency of Cassandra through the use of appropriate components: the Oracle Berkeley DB Java Edition High Availability storage engine for data replication and a replicated directory for maintaining membership information. The first component ensures that data replicas remain consistent despite failures. The second component simplifies Cassandra’s membership, improving its consistency and availability. In this short note we argue that the resulting system fits a wider range of applications, and is more robust and easier to reason about.
978-3-642-38541-4_17_Chapter.pdf (169.55 Ko) Télécharger le fichier
hal-01489458 , version 1 (14-03-2017)
Paternité
Panagiotis Garefalakis, Panagiotis Papadopoulos, Ioannis Manousakis, Kostas Magoutis. Strengthening Consistency in the Cassandra Distributed Key-Value Store. 13th International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2013, Florence, Italy. pp.193-198, ⟨10.1007/978-3-642-38541-4_17⟩. ⟨hal-01489458⟩
5295 Consultations
158 Téléchargements
