Bandwidth Prediction in the Face of Asymmetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An increasing number of networked applications, like video conference and video-on-demand, benefit from knowledge about Internet path measures like available bandwidth. Server selection and placement of infrastructure nodes based on accurate information about network conditions help to improve the quality-of-service of these systems. Acquiring this knowledge usually requires fully-meshed ad-hoc measurements. These, however, introduce a large overhead and a possible delay in communication establishment. Thus, prediction-based approaches like Sequoia have been proposed, which treat path properties as a semimetric and embed them onto trees, leveraging labelling schemes to predict distances between hosts not measured before. In this paper, we identify asymmetry as a cause of serious distortion in these systems causing inaccurate prediction. We study the impact of asymmetric network conditions on the accuracy of existing tree-embedding approaches, and present direction-aware embedding, a novel scheme that separates upstream from downstream properties of hosts and significantly improves the prediction accuracy for highly asymmetric datasets. This is achieved by embedding nodes for each direction separately and constraining the distance calculation to inversely labelled nodes. We evaluate the effectiveness and trade-offs of our approach using synthetic as well as real-world datasets.
978-3-642-38541-4_8_Chapter.pdf (304.14 Ko) Télécharger le fichier
hal-01489468 , version 1 (14-03-2017)
Paternité
Sven Schober, Stefan Brenner, Rüdiger Kapitza, Franz J. Hauck. Bandwidth Prediction in the Face of Asymmetry. 13th International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2013, Florence, Italy. pp.99-112, ⟨10.1007/978-3-642-38541-4_8⟩. ⟨hal-01489468⟩
165 Consultations
78 Téléchargements
