Abstract : Steganography plays an important role in the field of secret communication. The security of such communication lies in the impossibility of proving that secret communication is taking place.We evaluate the implementation of a previously published spread spectrum technique for steganography in auditive media. We have unveiled and solved several weaknesses that compromise undetectability.The spread-spectrum approach of the technique under evaluation is rather unusual for steganography and makes the secret message fit to survive A/D and D/A conversions of analogue audio telephony, re-encoded speech channels of GSM/UMTS, or VoIP. Its impact to signal statistics, which is at least concealed by the lossy channel, is reduced. There is little published on robust audio steganography, its steganalysis, and evaluation, with the possible exception of audio watermarking, where undetectability is not as important.
https://hal.inria.fr/hal-01492814 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, March 20, 2017 - 3:51:13 PM Last modification on : Monday, March 20, 2017 - 3:55:41 PM Long-term archiving on: : Wednesday, June 21, 2017 - 1:40:33 PM
Andreas Westfeld, Jürgen Wurzer, Christian Fabian, Ernst Piller. Pit Stop for an Audio Steganography Algorithm. 14th International Conference on Communications and Multimedia Security (CMS), Sep 2013, Magdeburg,, Germany. pp.123-134, ⟨10.1007/978-3-642-40779-6_10⟩. ⟨hal-01492814⟩
